bug with BLOCK and WBLOCK command
if  the entities that are selected for BLOCK or WBLOCK contain a dimension entity, then the dimension text will be recreated by BricsCAD, eventually destroying the dimension text format that has been created by another application (like ArchTools).
This behaviour is different from AutoCAD, where the dimension text remains untouched.
