Solid Editing issues
Hi this is the 2nd time i am posting this issues, i had posted the same thing one week before but there wasn't any response. Please let me know some solutions on the issues mentioned below
I am using Bricscad V10.1.4 i am working on Solid Editing commands i have come across certain issues as mentioned below
1) Solid Check command does not return any value after selecting the (ACIS) 3D solid model, in AutoCAD the same command returns SolidCheck=1 if a ACIS Solid model is selected
2) While using the command Color Edge, Copy Edge, Color Face, Copy Face and Shell the cursor does not change to pick box so its really very difficult to select the edge or the face
3) While using Color Face of Color Edge command how can i get the color dialog box poped-up, so that it becomes easier to pick the color from the dialog box rather then typing at the command prompt
4) Suppose if i have a Solid Box and would like to remove the material by maintaining a wall thickness of 2 mm from four sides. If i am using Shell command in Solid editing it shells the box from inside that's not what i want and the same works fine in AutoCAD
Sanjay.
The Bricscad user forum is meant to share information between users. For messages meant for the Bricscad development team (bug reports, feature requests, ...) please use the support request pages, they were created for that purpose, and allow much more efficient processing... in other words: they allow us to have more time left over to develop new features or improve things, which is probably exactly what you want. Thanks for your understanding!
