Printing wait time
Is this a bug:  When I hit the print button, the window "Printing" appears and takes forever to go away.  It take much much longer to print in V10 than V9.
  • Mine is ok for speed. It might be worth checking if it is the same for printing View, Extents etc. My V10 trims a band off each side in PPview when I choose View to print A1 sheets. Other sizes seem fine.
    Maybe there is a speed difference too?
  • We experienced really slow print times in some old HP plotters which showed a good printing times in other programs, we finally traced the problem to drivers that were not available for the OS that was being runned in the machine that had the plotter attached, make sure that your drivers match the OS and that might correct the problem
    José
