PlotOutputPath
I want to set my plot output path to the current drawing path
But this line:
(setvar "PlotOutputPath" (getvar "DwgPrefix"))
gives me NIL
gives me the current drawing path fine
but
(getvar "PlotOutputPath")
just gives NIL despite what appears in the Settings dialog box
  • This is because, while DWGPREFIX is a system variable, PlotOutputPath is a so called 'preference'. You can get (and if applicable set) a system variable's value simply by typing it's name on the command line or via (getvar xxx) /(setvar yyy newvalue).
    : dwgprefix
    DWGPREFIX = "C:\Users\ferdinandj.BRICSYS\Favorites\Documents\" (read only)
    To Get (/or Set)  a preference is a bit more complicated.
    Preferences  live in the registry (user profile)
    the typical location of the 'PlotOutputPath' preference is:
    HKEY_CURRENT_USER\Software\Bricsys\Bricscad\V10\en_US\Profiles\PROFILENAME\Config\Plot
    Following Lisp function returns the value of the PlotOutputPath preference:
    (defun getPlotOutputPath (/ thisProf thisKey)
      (setq thisProf (vla-get-ActiveProfile (vla-get-profiles (vla-get-preferences (vlax-get-Acad-Object)))))
      (setq thisKey (strcat "HKEY_CURRENT_USER\\" (vlax-product-key) "\\Profiles\\" thisProf "\\Config\\Plot"))
      (vl-registry-read thisKey "PlotOutputPath")
  • Cool! Thanks.
    So how do I set  "PlotOutputPath"?
    I know, I should start digging into Visual Lisp.
    I'm sure I can figure it out on my own.
    Can anybody recommend a good online resource for all that Vl-, Vla- etc. stuff?
    I'm fairly good with conventional (Autocad R14) Lisp
