BeginCommand-statement
In Bricscad V9 the following (simplified) code in the ThisDrawing-Module worked (it should manage to
switch the aktive Layer when the Xline-command is triggered):
Public WithEvents AktivesDokumentObjekt As AcadDocument
Public Sub Init() '...Initialize AcadDocumet
Set AktivesDokumentObjekt=ThisDrawing.Application.ActiveDocument
End Sub
Private Sub AktivesDokumentObjekt_BeginnCommand (ByVal Commandname As String)
SelectCase Commandname
Case "XLINE"
ThisDrawing.ActiveLayer=ThisDrawing.Layers("FC-S-Hilfslinie")
EndSelect
End sub
In V10 it doesnt work any more ! What has changed ?
kind regards from Austria
Peter Schriebl
You wrote: "In V10 it doesnt work any more ! What has changed ?"
Not sure, but perhaps your spelling has evolved...?:
I believe it should be:
Private Sub AktivesDokumentObjekt_BeginCommand(ByVal Commandname As String)
in other words change
_BeginnCommand
to
_BeginCommand
Seems to work for me...0 -
After checking the spelling (its ok in the original-code) I could figure out, that the line
"Set AktivesDokumentObjekt = ThisDrawing.Application.ActiveDocument"
causes an error like "Typen unverträglich" (errcode=13)
Have I made a mistake in the declaration of the "AktivesDokumentObjekt"?
Peter Schriebl
