counting area
how can i count area and length in bricscad ?
Area of a closed polyline, circle or elipse is given directly on the Properties pallette by picking the object.
So does hatching, so you could temporarly hatch any area to read off the area covered by the hatching.
Length of a line displays similarly.
Try using the AREA command:
: area
Entity/Add/Subtract/<First point>: a
Adding: Entity/Subtract/<First point>: e
Adding area<Select entities>:0
