Making cuts in 3D
i am a Autocad user,learning bricscad. in autocad 2010 there is solview and flatshot what are the similar options in bricscad?
how do i make cut/Section's in 3D ?
-found the solid toolbar to create section planes of 3D solids.
Is there a plan to create a command that is equivalent to command FLATSHOT (or SOLPROF)? Maybe you can improve the existing command FLATTEN?
