menucmd not supported ?
I have a menugroup myapp, when trying to disable a menu or menuitem this does not seem to work. Is the menucmd function not supported ?
(menucmd "Gmyapp.ID_MNUmymenu1=~")
The ID i use is the correct one (checked it in customize dialog).
It wasn´t supported in some older Versions (V6 ?) and only partially in V7 (no tablet-, screenmenu and such)
No problems so far with V10, it seems to works nicely.
ok i'm using v10, did you test it, because i can't get it to work.
I wouldn´t say that I tested it, I just gave it a go ...
From within LISP-command I use (menucmd "GjeTools10.ID_bhl20=!.") for checkmarks - this works.
After your experience, I tried this (menucmd "GjeTools10.ID_bhl20=~") and the item was properly greyed out.
In this case I set the item-ID in a proper mns-file, I tried the same in the customize-dialog with
an item-ID asigned by that cui-thing, ID is MM_00015, here´s what I found out :
(menucmd "GjeTools10.ID_MM_00015=") - nothing happens
(menucmd "GjeTools10.MM_00015=") - the item is now greyed out
I don´t know if you assigned the ID to your menu item, but, just out of curiousity, what happens if you try this
(menucmd "Gmyapp.MNU_mymenu1=~")
Good luck0 -
Thx,
I find out it seems to work for submenu's or command's but not for the pull-down menu itself. I have different modules and i want to grey out not authorized modules (=menu's). I splitted the menu's up now in partial CUI's and only authorized menu's are loaded, so there is no need to grey-out.
