Toolbar esnap button toggle help
I do not find the diesel code for toggling toolbar icons documented. I notice that with the default diesel strings the buttons toggle correctly when the individual buttons are pressed, but that when all esnaps are toggles off by the ESNAP button at the bottom of the screen the individual buttons do not toggle off. Can anyone provide a diesel function that will toggle the icons correctly when ESNAP is toggled off? I've tried several diesel strings that I think should work. I probably have the commas in the wrong places...
