Chamfer
Chamfer does not works as it should be. For example, two crossing lines :
  • when selecting the first line beneath the second line (say 6 o'clock)
  • when selecting the second line at the right side of the first line (say at 3 o'clock)
  • I expect the chamfering being done in the quadrant between 3 and 6 o'clock
  • however, the chamfering is done in the quadrant between 3 and 12 o'clock!
Do I have to make some settings in the chamfering menu or is this a bug?
I'm working with V10.2.3, english version.
Anyone an idea?
Best regards,
Tom
  • This problem most probably has been fixed in V10.2.4 (the current Bricscad version available for download is V10.2.8)
    If the problem is not solved by upgrading to  V10.2.8, then please file a Support Request: the user forum is not the right place to go if a response from a Bricsys analyst or developer is desired/expected.
    To be informed when new Bricscad releases  are made available for download, you can subscribe to the following Bricscad Releases RSS feed: http://www.bricsys.com/rss/rss.jsp?channel=bcad
    Kind regards
