command line arguments to bricscad.exe
Is there a list of command line arguments for bricscad.exe?
I have a dual screen setup, and I would like the option of opening a dwg file in a new instance of Bricscad,
which I would put on the other screen.
"C:\Program Files\Bricsys\Bricscad V9\bricscad.exe" opens a new instance. Or just double-click on a shortcut to it. Then any file you double-click on will open in the new instance, until you click on the other instance to make it active.
Command line (from Customizing Bricscad v8):
/b scriptname.scr <== run script at atartup
/l <== stop the splash screen from displaying
/s "alternative supporting files search path"
/p "profile.arg" <== loads a profile from a .arg file
There was nothing listed in this reference to control the display.
