MNL load is reversed
hi,
I have a function that's shows DWT files in a dialog, after user selection the files it opened with
(vla-sendcommand
(vla-get-activedocument
(vlax-get-acad-object)
(strcat "(command \"_.OPEN\")\n" dwt-file "\n")
Apparently in this drawing the partial CUI files (and there MNL files) are loaded in reverse order. Because i have MNL's for several partial CUI's this is a problem because the main MNL is loaded last. This MNL however defines functions used in the other MNL's, and therefor nothing is loaded.
Trying this in the command-line results in the same:
(setq f$ "C:\\MyApp 2008\\templates\\myapp 2008.dwt")
(command "_open" f$)
MNL's are loaded in reverse order.
regards
it's easy to find a workaround but it isn't that neat...
No, it isn't. Thanks for finding and reporting this, it will be fixed soon now.
