BricsCAD V10 with Wine (Ubuntu 9.10)
I tried installing BricsCAD V10 Pro via Wine and it installed without error messages. however, I cannot start the application. it appears in the application start menue, but nothing hapens and I don't even see any error log.
does anyone know where to find a 'how to' description?
what console you told about?
I am install BricsCAD roght now with this command
~>wine BricscadPro-V10.1.11-1-ru_RU.exe
I got an Bricscad shortcut in my kde menu (same gor gnome I guess)
i look at it properties and got a line i need to run from console
~>env WINEPREFIX="/home/<YOURUSERNAME>/.wine" wine "C:\Program Files\Bricsys\Bricscad V9\bricscad.exe"
hahaha
I found why it not working
))) LOL
v9 is a proble, it should be v10
~>env WINEPREFIX="/home/<YOURUSERNAME>/.wine" wine "C:\Program Files\Bricsys\Bricscad V10\bricscad.exe"
thats it.
You can edit your shortcut. But it is preffered that you run it from console. So you got a log.
Have you tried PlayOnLinux? I've downloaded but not yet tried it.
And how you write expansions BRX in Wine?
