Bricscad for Linux alpha 10.3.3
Hello everyone,
a next Bricscad for linux alpha has become available from the usual location:
http://www.bricsys.com/open/common/download.jsp?p=B4L&l=en_US&site=1
- It is now possible to save a dwg.
- Temporary graphics have been improved. It is now possible to display trackers and osnap markers.
- A partial version of the lisp engine has been added.
Kind Regards
Tijs
Hi, good job ! :-)
Still some issues, just tested 5 minutes :
1) 3d drawings are NOT displayed correctly.... I guess the engine is still not there ?
2) Some crashes here and there
3) On launch didn't find the support path, so it didn't load menu. Loading manually works.
4) Didn't get fonts... maybe because of point 3.
5) Slow/hangs on large drawings. Also display scrolling slows down on complex drawing, but still usable.
Ciao
Max
I am so happy one step closer for release
I am test it right now
Just a good work!
1) Fonts loads only from basedir, that's normal for alpha, that's good for alpha, because they are loading!
2) Saving... M-m-m, I'll give that version to one of our designer, may be later we will describe some bugs.:)))
3) Printing...We are waiting for it...
4) Saving as... It can be instead of printing, of course, but it is not work.
This is excellent,
on my Xubuntu 9.10 and debian 5 it works, (alpha but works)
and it look beautifull
Good morning.
Some information on the testing today.
By clicking "hatch" no hatch is shown. If I choose "gradient" and then pass the tab "hatch" Bricscad crashes and releases this output:GLib:ERROR:gmain.c:1963:g_main_dispatch: assertion failed: (current->dispatching_sources == ¤t_source_link)
Abortito (core dumped)
[Giacomo@PCLinux BricscadForLinux-10.3.3-1-en_US]$
Bye.Giacomo
Cudos. I still cannot believe that you are moving on so fast. Two weeks ago the usual interface was almost not present, now it's there.
A suggestion. Could you please make a thread for Alpha version announcments, which should be used ONLY for announcing (no user comments there, not forced, simply stated). So I could subscribe the thread and get information early. If you do so, please continue to make these threads as the current one for user feedback.
It looks absolutely LOVELY!
and it's FAST. (some of that is probably going to go away as more of the modules are brought up, connected in, and made to work)
I had to do some work on AutoCAD in XP yesterday - same machine - and all I did was wait and wait and wait.
This product is going to be absolutely BRILLIANT!! May the customers come flocking.
(bricscad:4995): Gtk-CRITICAL **: gtk_window_realize_icon: assertion `info->icon_pixmap == NULL' failed
(bricscad:4995): Gdk-CRITICAL **: gdk_drawable_get_depth: assertion `GDK_IS_DRAWABLE (drawable)' failed
Setings->Program options->Display->WinGDI ???????????? It as well as where?
Graphics very slow. The file 16Mb - to work difficult.0 -
It's not possible to attach images (snapshots) to this forum?
If draw a line, then finish the line with enter or space, wait a second, then move the cursor and have two cursor on the screen. Only one moves.
Hello,
I am a Linux novice, Can anybody tell me how to install Bricscad for Linux?
Thank's
you should know some about file system structure in unix
depend at your knowledge, you will understand my answer or not.
my distribution is opensuse but afaik same for fedora, debian and ubuntu
It can be installed in /opt (normally most distributions)
Personnaly I prefered install all my alien(not from distrubution) stuff in my local directory
so I have an bin directory in my home directory
/home/<myusername>/bin
you can make your BricsCAD directory with command:
mkdir
(man mkdir give you aditional help about mkdir command)
~>mkdir -p /home/<yourUserName>/bin/BricsCAD
then you should unzip your archive in this directory
~>unzip BricscadForLinux-10.3.3-1-en_US.zip -d /home/<yourUserName>/bin/BricsCAD
<the end> installation complite
to run BricsCAD
you should change directory <WhereYoUnzipIt>
~>cd /home/<yourUserName>/bin/BricsCAD
and run script
BricsCAD>sh ./bricscad.sh
!it is important that BricsCAD should run from directory where it unziped
global path to BricsCAD directory will not work if you run from another location
so if you change ddirectory to root and run with all path
/>sh /home/<yourUserName>/bin/BricsCAD/bricscad.sh
this does not work because of script
~> cat bricscad.sh
#!/bin/sh
export LD_LIBRARY_PATH=`pwd`
exec ./bricscad $*
you can change it
#!/bin/sh
export LD_LIBRARY_PATH=`/home/<yourUserName>/bin/BricsCAD`
exec '/home/<yourUserName>/bin/BricsCAD/bricscad $*'
now it sould work from any location. So you can make symlink to shell script and put it to known path and now it will run as any normal program
~>sudo ln -s /home/<yourUserName>/bin/BricsCAD/bricscad.sh /usr/bin/brickscad
now you can use Alt+F2 in gnome or KDE type bricscad and BricsCAD sould work for you
and as for test
so now all important things work
thank you.and as for priority
#1 dimensioning
#2 lisp
#3 printing
good work thank you guys
<a href="http://i47.tinypic.com/29mq3yr"><img style="float:right; margin:0 0 10px 10px;cursor:pointer; cursor:hand;width: 320px; height: 200px;" src="http://i47.tinypic.com/29mq3yr" border="0" alt="image BricsCAD for linux 10.3.3" /></a>
sory for triple posting I remember 2 more minor problems
They was allready discussed.
1. keyboard not work as I expect for Delete, F1-F12 keys
2. looks like ttf fonts does not supported yet
Confirm Delete from keyboard and F1-F12 don't work (have spanish keyboard and Ubuntu 9.04)
Very east to install under Ubuntu, just double click to the downloaded file, extract all the files to a folder, and double click to the file "bricscad.sh"
Bricscad runs very fast!!!
Very good improvements. Seems promising!
Bricscad is very fast with ubuntu 9.10 64 bits. Interface is beautiful.
Waiting for next alpha snapshot and after some desappointments I'm now confident about a working native linux Bricscad in a near future.
Congratulations.
Fires up on my Gentoo 64 bit box. Panning and zooming working well. Keep up the great work!
I got the errormessage when I run the script:
eror while loadin shared libraries: libjpeg.so.61: can not open shared object file: No such file or directory.
can you be so glad to explain what you are doing? and in this case maybe we can help you more.
I had this problem
Resolved by installing the 32bits libraries on my ubuntu
sudo aptitude install linux32 ia32-libs ia32-libs-gtk
There are my procedure:
1. mkdir -p /home/<yourUserName>/bin/Bricscad
2. unzip BricscadForLinux-10.3.3-1-en_US.zip -d /home/<yourUserName>/bin/Bricscad
3. Modify bricscad.sh
4. Run sctipt
I can not install the 32bits libraries on my Mandriva.
On my Fedora and Ubunto it works, but Mandriva still don't works.
Good morning everyone. I have a problem. My files are on a windows sever (windows server 2003 R2). My Fedora 12 is regularly on the network and can access the server via nautilus and using the Linux program. But if I open Bricscad not shows me the network mounted partition. So I can not open files that are on the server. I can not even tell Fedora to open *. dwg with Bricscad. How can I solve this problem. It 'a very important thing for me. Thank you all for your patience.
2Shun-Hsiang Hsiao
it will be very good if you give a log from runningsh bricscad.sh
little bit confused about that
2Cielito Lindo
very strange
khm... ok
you should look at smbmount
man smbmount
Personally I prefered linux server with nfs, ftp or smth different from samba. But that is your option it can be done.
I am not sure that this is depends on distribution. But Desktop Environment does, or better say file manager, that you use.
I prefered KDE4
in systemsettings you can choose "aditional" tab, and choose "file type" (name can differ couse I have different language)
there you can choose dwg file extension (I have it in image section) and here I can add application to run with. right now I have it automatic with wine Bricscad.
I am pretty sure you also can do this with gnome.
Nice work guys, have plans to build a native 64bits?
Hello everyone,
I tired to run it on openSuSE 11.2. After launching the script, I got the following message:
(bricscad:6525): Gdk-CRITICAL **: gdk_drawable_get_depth: assertion `GDK_IS_DRAWABLE (drawable)' failed
drmRadeonCmdBuffer: -22. Kernel failed to parse or rejected command stream. See dmesg for more info.I don't know, where to find anything helpful for locating the problem in the output of dmesg. uname -a says:
Linux n0908a34 2.6.31.8-0.1-desktop #1 SMP PREEMPT 2009-12-15 23:55:40 +0100 x86_64 x86_64 x86_64 GNU/Linux
Can anyone help?
Hello again,
I have forgotten to mention that the installation of
libxerces-c-3_0
did not solve the problem. The message is still the same.
@Bernhard Karl Bachner
did you change directory to bricscad before run bricscad.sh script?
I alo use opensuse 11.2 (x86-64) no problem here.
<img src="http://i47.tinypic.com/29mq3yr">
@Andrey Didencool
thank you for your reply. Yes, the current directory is that one, where the shell script and all the shared object libraries are located. After work I will try it at home with fedora FC12 again. I'll see, what's possible there.
On my notebook at home it works well with fedora FC12. I don't stand waiting for the release ;-).
happy for you, and good luck:)
While I was answer to Shun-Hsiang Hsiao. I have discover a little problem
I change a script in that way
~/bin> cat bricscad
#!/bin/shexport LD_LIBRARY_PATH=/home/<user>/bin/BricsCAD/
exec /home/<user>/bin/BricsCAD/bricscad $1
~>sh bin/bricscad ../test.dwg
but emty bricscad was runned
is it possible to open dwg file throw command line at that stage?
