Grid and Entity Snaps
Does anyone else find it difficult to use grid and entity snapping at the same time? It always seems that I have to switch one or the other off to snap to where I want. It's as if the attraction of one snap type overrides the attraction of the other in an unhelpful way. If I am soing something wrong please enlighten me.
Thanks
Jamie
  • I don't generally have Grid turned on, but it seems to act in a completely inert way.
    Snap and Esnap don't go very well together - Esnap overrides, but Snap can cause you to miss a point close enough for Esnap to work.
    Snap also turns itself on and off at times such as when selecting entities to Stretch. Obviously chosen to switch at appropriate times, the switch points have not always been the same and I'm never quite sure when Snap will be acting and when not.
