Leica Disto
I saw the Disto was supported in V9, but have seen nothing about it in 10. Is it and will it continue to be supported, in Bricscad and any vertical applications? And what sort of commitments are there that vertical application providers will continue to support Bricscad? I can't afford Architecturals, but could use an affordable architectural field drafting package especially for as-builts.
I wasn't aware of such support in V9.I've had a bluetooth enabled Disto for some 6 or 7 years, seemed a great idea at the time, but I wasn't able to find any software that was really practical other than a few specialist and expensive packages. Things may have changed in the meantime as it's a long time since I searched. I reverted to pen and paper and drawing up later and still find that best for me.Architecturals would not really help with this, unless you have an assistant drawing with CAD as you go - in which case you could use almost any CAD software and simply shout dims across the room instead of using bluetooth or similar.
