Paper Space units for scaling
Hello, perhaps someone will be able to help -
when in model space I draw a line and use 'DIVIDE' type linetype and scale '1', and I have two paperspaces different scales: one is 1:50 and the other 1:100.  the 1:50 works fine but the 1:100 shows the line differently - with much spacing between the dashes and the dots, as if in different scaling.  I was told that in AutoCAD the problem can be overcomed unchecking the box 'Paper Space units for scaling' in the layer manager, but I was unable to find it in bricscad.
Help please
  • Is PSLTSCALE the one you are looking for?
    I set that to 0 in on_doc_load.lsp so it happens as I open each file.
  • PSLTSCALE it is!
    Thanks a-lot, thats exactly what I was looking for :)
