won't load on_doc_load.lsp
For some reason I can't get the on_doc_load.lsp file to execute on starting a new drawing.  Is there a setting somewhere to tell Bricscad to look for this file?  Also, even the command (load "on_doc_load") will not work.  I have updated the search paths so I don't think that is the issue.
  • Perhaps there is something in it which stops it from running.
  • That was it.  I had some tablet_setButton commands which I guess are no longer supported.  I commented them out and the rest appears to be working.  Hopefully I can find some way around that.  The software should probably display an error message notifying the user of the problem.
