scale hexagonal viewport
For setting the scale of a rectangle viewport, there is no problem, but how to scale a hexagonal viewport ?? In the properties bar, there is no possibility to any settings.
Best regards.
Peter Bontekoe
A polygonal viewport consists of 2 entities: a polyline used for clipping and the actual viewport. If you select a polygonal viewport both entities are selected. To change the scale of the viewport use the drop-down list at the top of the properties bar to select the viewport only.
Thanks.
Peter
