Time stamp error?
For some reason, the time stamp feature, I planed to make use of for my project calculations, does not work?
The time recording stops after 0.0010 seconds and stays there for the entitre project...
Any one has an idea on what could be hapening?
running XP64
using latest build 10.2.13 build17830
> ...the time stamp feature...
Do you mean a date field? And if that is the case: what type of date field are you using?
Is this question perhaps related to programming?
Note: fields should update after a REGEN and when you save, open or print a drawing.0 -
when you type in the command "time"
you'll get information on when the drawing was created, when it was last updated, the total editing time and the elapsed timer info.
Both "total editing time" and "elapsed timer" give 0 days 0 hours 0 minutes 0 seconds, even if I have the elapsed timer set ON.
I use this information to make my post-project calculations.
The fact it doesnt work propperly makes it hard to make an accurate finalisation of a project.
You are right, the TIME command doesn't work. Support request!
I verified with an original autocad drawing i received from a client.
The original timestamp is correctly displayed, but my worktime is not added to the drawing..
Very irritating when you do hourrated work...
Been broken since V8 I think though haven't checked often
