pedit
I miss the "multiple" option for PEDIT (or a PLJOIN-command).
Is there any workaround or - better- a improved PEDIT-command in future...
Regards Jochen
You could look at GeoTools...
Hi Heinz-Joachim,
Workaround is to pre-select all lines/plines you want to join, then call pedit. In pedit call join and then pick all those lines-plines again that you want to join. Hope this helps, maybe someone else knows a better way.
Simon.
Thank you for the hint.
Meanwhile I found P_ed.lsp by Theodor Schönwald (see http://www.lehrer.uni-karlsruhe.de/~za685/cnc/cnctools.htm , cnc-tool_01.zip) - this does the job!
Regards
Jochen
