Adding a cancel to a menu
On prevoius versions of Bricscad, I had a "^c^c^c" command added to the right click popup menu (would be handy if that was built in) and also to a toolbar.
The main reason I used this was to cancel from an object that had its grips highlighted. When I use the command now, the grips disappear but the entity is still dotted i.e. the command dosent behave the same as pressing the Esc key.
Any ideas out there?
