DCL & LISP: is there a way to continue lisp after (start_dialog)
Hello everybody,
I am trying my hand at some DCL-programming. The problem I am faced with is that I would like to display a dialog containing a "Please wait" message before some longish lisp action is executed. But the start_dialog command effectively suspends the lisp and the program sits there waiting for user input. Is there a solution for this other than using print/prompt to display the "Please wait" message in the command line?
Thanks in advance, Roy.
Dear Roy, there is no way to have DCL dialogs being "modeless" ...
You might have a look at DOSLib from McNeel - not sure, but I guess it has a modeless message box.DOSLib is free - and available for both Acad + Bricscad.
OpenDCL will certainly do what you want (and much, much more). Its also free.
Dan and Torsten thank you for your anwers.
I know about DOSLib. But my goal, at least for now, is to do without these functions and try to use "pure lisp".
OpenDCL is already on my things-I-need-to-learn-more-about-list. It is one of the reasons why I chose the Pro version.0 -
Roy,
Instead of using please wait, how about using these functions
(acet-ui-progress-init "message" val) ;val = time integer
(acet-ui-progress-safe n)
(acet-ui-progress-done)0 -
Daniel thank you for that tip. Note: the progress bar is displayed in the status bar but the text message is not (BC 10.2.14).
Hi Daniel, Hi Roy,
indeed, using progress bar is the better idea :-)
Unfortunately, Bricscad's progressbar does not yet display a preceeding text ... but Lisp interface already supports this, for compatibility reasons.
I hope, it will be added once.0
