BricsCAD V9 - VBA - GetPoint problem
Hello.
I've got plenty of old vba macros written for autocad 2004. Now I'm trying them in BricsCAD V9. The problem is with the method getpoint:
center = ThisDrawing.Utility.GetPoint(, "Prompt: ")
It worked ok in autocad. In BricsCAD it doesn't. When I start the macro it works ok until it gets to this line. The "Prompt" appears in the commandline. The program doesn't wait for the point to be shown (selected). The program "hangs" - i can't terminate it, i can't turn the BricsCAD off. Ctrl+Alt+Del helps.
BUT! If I use Step Into (F8) from menu Debug and perform the macro "one line after another" everything from the Begin Sub(), including this line and further code, to the End. works correctly...
Where is the problem?
P.S. I'm not a developer. I write simple macros. I'm hoping for Your help.
wojtek
The problem isn't in fact the problem. GetPoint, GetString and other Gets... work fine. Wheather I start it with Step Into (F8) from Debug menu or Run (F5) from Run menu.
What I didn't mention before, is that I start vba macros using LISP. I have my old lisp codes that worked with autocad 2004.
(defun C:vba_macro_short_name ( )
(command "_-vbarun" "macro_name")
);defunVBAMacros that don't use GetSomething methods work fine.
Macros with Gets... fail. They seem to be started with a parameter or something... I don't know. This lisp code is the only one I have ever written.
What's wrong?
looking for Your help
wojtek
Hi Wojtek,
It is difficult to judge what might be the problem you are encountering: For me, both the .Get.. commands work, and I can start my macro's with a lisp command, just the way you use it as well.Maybe you can post your macro here, so we can see what goes on?
By the way. to make your Prompt appear under the command line you can add an Carriage return character (vbCr):
center = ThisDrawing.Utility.GetPoint(, vbCr &"Prompt: ")
Gerrit
Thank You for Your reply.
Here I post the simple macro that when started with Run (F5) from menu Run works fine.
Public variant_variable As Variant
Public string_variable As String
Sub simple_macro()
variant_variable = ThisDrawing.Utility.GetPoint(, "pick a point")
string_variable = ThisDrawing.Utility.GetString(30, "enter text")msgbox string_variable
End SubAnd started by LISP fails:
(defun C:smpl()
(command "_-vbarun" "simple_macro")
);defunCommand line looks like that:
: smpl
: _-vbarun
Nazwa macro: simple_macro (I use polish bricscad - "Nazwa macro" means "Macro Name")
pick a point
:The program doesn't wait for the point. Cursor doesn't get the shape like when waiting for a point, but looks and works like when selecting objects. BricsCAD works well later - I can draw, save and open drawings. VBA "hangs" - can't stop the macro.
Other macros that don't use .Gets work well started with LISP.
It works here, but then I run the latest version of BricscadPro (10.2.14).
This is my output:
: smpl
: _-vbarun
Macro name: simple_macro
pick a point
pick a point
enter textMyTextI have no idea why it would prompt "pick a point' twice.
Works with 9.3.13 English as well
I upgared my program to 9.3.14 Polish and it works fine now.
Thank You for Your support.
wojtek
