How to use previous selection?
 i'm selecting "previous selection" on "prompt menu" but bricscad selects nothing.
i'm using version 10.3.11 build 18258.
  • I am using the same version and "previous selection" on the "prompt menu" seems to work just fine. Of course, and I am assuming you know this, a previous selection (for instance a selection that has been used in a previous command) has to exist in the drawing for this menu item to work (I don't know why this option isn't disabled if there is no previous selection).
  • Yes, i know this but it doesn't work (from prompt menu or "p" shortcut). Thanks for reply.
