COPIED POLYLINES CHANGE WIDTH ??
Odd question.I simply have polylines with different end widths (ICAD calls TAPER), and when I copy them, they loose the varied widths and return to 0 width. This does not happen in ACAD. YET donot expect it to be, just do not understand why the width association changes ????????Thought OH WELL, just make a block andinsert as needed - OH NO, SAME THING.THIS is NOT GOOD at all, and i'm usingMOST Curent Bricsnet .27Anyone care to expand on what the programis doing, and not keeping the width associationwhen either copied, or even to blocks.TOO big of a pain to pedit each one back tothe desired (taper) width. Or am I just beingbrain dead and missing some sort of setting which I'm not acustomed to.Thanks, in advance
