Controlling DRAWORDER by VBA
Using V9.3.13 Pro.
I'm creating a block by VBA containing many Hatches, and insert it in Modelspace.
Using attached routine, I send the blockref to the background. That works ok.
I run the same macro, create an other block with hatches and insert it in Modelspace.
Attached routine is called again to send the new blockref to the background. That works BUT....
the previously inserted blockref pops to the front!
I played with various settings for SORTENTS, HPDRAWORDER and DRAWORDERCTL but none seems to influence this behaviour.
Anyone who can give me clue on this one?
TIA,
Arno van Eeuwen
Public Sub SetDrawOrderToBack(entity As AcadEntity, SendToBack As Boolean)
  Dim sortentsTable       As AcadSortentsTable
  Dim cadObjects(0)       As AcadObject
  Dim MsBlock             As AcadBlock
  Dim MsDictionary        As AcadDictionary
  Set MsBlock = ThisDrawing.Modelspace
  Set MsDictionary = MsBlock.GetExtensionDictionary
  On Local Error Resume Next
    Call MsDictionary.AddObject("ACAD_SORTENTS", "AcDbSortentsTable")
  On Local Error GoTo 0
  Set sortentsTable = MsDictionary.GetObject("ACAD_SORTENTS")
  Set cadObjects(0) = ThisDrawing.ObjectIdToObject(entity.ObjectID)
  If SendToBack Then
    Call sortentsTable.MoveToBottom(cadObjects)
  Else
    Call sortentsTable.MoveToTop(cadObjects)
  End If
  ThisDrawing.Application.Update
  Set sortentsTable = Nothing
  Set MsDictionary = Nothing
  Set MsBlock = Nothing
  Erase cadObjects
End Sub
  • Small modification to previous example solved the problem:
    First try to GET the Dictionary, and in case that fails: ADD the dictionary.
    Arno van Eeuwen
      If sortentsTable Is Nothing Then
        Set sortentsTable = MsDictionary.AddObject("ACAD_SORTENTS", "AcDbSortentsTable")
      End If
      If SendToBack Then
      Else
      End If
      Erase cadObjects
    End Sub
