Lwpolylines
I'm trying to extract the coordinates of vertexes of a Lwpolyline. Up to ver 7, ' I could extract the coordinates, including the elevation, for each vertex. It was kept under group code 10. Now I found, that only the y,x Coordinates are kept under group code 10. What is the code for the elevation of each vertex ?
Raam.
group code 38 holds the elevation of the entire LWpolyline and appears only once.
LWpolylines are always planar (flat), unlike 3dpolylines.
(if the LWpolyline is angled with respect to the Z axis,
then the group code 210 holds what is called the "extrusion" direction,
which is a 3D vector normal to the plane of the LWpolyline)
Thank's
