Crashing at Print Preview
I have been getting a fairly consistent crash failure when going to the print preview function. Here are the details from the dialog box:ICAD caused an invalid page fault inmodule ICAD.EXE at 016f:00413e54.Registers:EAX=00000000 CS=016f EIP=00413e54 EFLGS=00010202EBX=00c8ac50 SS=0177 ESP=00abebdc EBP=00abebe8ECX=0008cf6e DS=0177 ESI=00233db8 FS=c19fEDX=00000000 ES=0177 EDI=00000000 GS=0000Bytes at CS:EIP:f3 ab 13 c9 66 f3 ab eb 5a 83 f8 03 68 00 01 00 Stack dump:00000000 00c8a5c0 00c8a560 00abec04 00461d4b 00000002 00c8a5c0 00000000 00000000 00000000 00abec60 004e7a59 01ac6470 00c8a5c0 00c8ac50 00000000This has happened with more than one drawing, but not so consistently that I can identify a certain pattern. In any case, It is becoming fairly annoying. Is there any fix coming for this? (I'm using latest version). Thanks-
  • I also have had the same problem but I also can't find a pattern in it, sometimes it works well, sometimes not.
  • Since the original Intellicad 98, if you do a print preview and an auto save kicks in while doing so, the program crashes. I have gotten in the habit of doing a "quick save" before doing the print preview to save myself the hassle of the crash.
