Bugs still not fixed
I recently down loaded IC2000 v2.2.0027 (replacing .0021). These are bugs that are not yet fixed that go back to .0010 and .0019). UNDO command somewhat better but still not right. Undo will some times undo things out of the sequence they were created often things done hours earlier. Redo does not restore these things and is of no help.The undo controls the (DRAWINGS SETTINGS, DISPLAY, PROGRAM INTERFACE, UNDO CONTROLS) still don¿t save and must be set for every drawing every time you bring it up.STRETCH still doesn¿t handle broken lines (HIDDEN, DASHED, PHANTOM, etc.) right (moves instead of stretching when the pick box crosses the line through a broken section.ENDPOINT snap is still always on (even when it¿s off) so far as poly lines are concerned when ever any other Osnap is on.IStill get ¿ghost¿ crosshairs, pick boxes, and the like. REGEN gets rid of them but it is annoying.When you edit several lines of DTEXT at the same time (the text: is usually different) and change the text justification, instead of repositioning the newly justified text in the same position of the old (same origin of insert point) it changes all the origins to 0,0,0. If I edit the justification one text line at a time it works fine.Anyone else notice these and want them fixed? Anyone find anything else?Templeton
