Parametric Constraints for Bricscad V10
Hi Everyone,
We have released a new add on product for Bricscad called Parametric2D, for adding parametric constraints to Bricscad drawings. You can find more information about it at http://www.3dbrains.com/Parametric2D.html, or on the Bricsys application area.
Its got a convenient tool palette which you can use to add relational constraints like parallel, perpendicular, etc and dimensional constraints like length, radius, etc. The constraints get added as regular Bricscad dimensions (aligned, rotated, radial, etc) with one difference - editing them updates the drawing!
A limited functionality evaluation version is also available for download, and you are also welcome to see the demo video.
We hope it will be useful for anyone looking for a parametric constraint solution for Bricscad!
