problem with PDF Creator
Strange... I set up my drawing to plot on a 24x36" sheet, but I can't scale the drawing in the viewport properly (SCALE-1/20xp, etc.  1/240 made it smaller).  I've verified that my scale is correct in model space, with 1:1 units.  Once I created my pc3 set-up, the scale in the page layout box changed to custom, at a 1:24.5 scale.  The drawing is set up to be plotted at 1" = 20'.
I suspect I'm just missing something simple... clues, anyone?
Thanks,
Tom
  • Well, it seems I've solved it.  Using the properties bar for the viewport, and making sure my plot scale in the plot set-up box was set 1:1 was the trick.  Part of the learning curve after switching from AutoCAD, I guess....
