Clearing the Active SelectionSet
What does the Clear method on the ActiveSelectionSet do.
After I have the user select some items on the drawing, I do some processing.
Then I want to clear the selected (and highlighted items) so I do the following (myActiveDoc is a reference to the Active Document)
myActiveDoc.ActiveSelectionSet.Clear()
After doing this, the property myActiveDoc.ActiveSelectionSet.Count is not zero as I would expect.
Another question, are selected items necessarily highlighted. Is there a way of unhighlighting all items?
Thank you , Mark Bosley
  • Hi Mark,
    This code seems to work as advertised, you may be needing to cache a copy of the ActiveSet to variable.
     public static class Commands
        [CommandMethod("doit")]
        public static void test01()
          var app = Application.AcadApplication as AcadApplication;
          var doc = app.ActiveDocument;
          try
            AcadSelectionSet aset = doc.ActiveSelectionSet;
            doc.Utility.Prompt(String.Format("\n{0}", aset.Count));
            foreach (AcadEntity e in aset)
              e.Highlight(true);
            //foreach (AcadEntity e in aset)
             // e.Highlight(false);
            aset.Clear();
            aset.Delete();
          catch (System.Exception ex)
            doc.Utility.Prompt(String.Format("\n{0}", ex.Message));
