Crosshairs leaving ghost image
When I realtime zoom with the mouse wheel the previous cross hair position remains shown and a second set of crosshairs are shown in the new position following the zoom.
This does not happen in the toolbar realtime zoom function, just vis the mouse wheel.
Any ideas?
Also I am experiencing a number of crashes (no warning, C++ error, warning with option to save and a crash that causes a kaleidoscope effect with 100's of copies of the current drawing over each other). The crashes happen when clickng on an entity or real time pan with the mouse wheel and have been present in v10.3.12-10.3.14.
  • The problem with the  previous cross hair being left behind has been fixed in V10.3.15, which is about to be released.
    The crash with the kaleidoscope effect is new to us: we would be grateful if you filed a support request and attached a drawing with which you experienced the problem.
  • Yes I have the "kaleidoscope" crash fairly frequently too; though I haven't been able to reliably reproduce it to submit a support request.  It has only ever happened to me in paper space as far as I can remember but I've been too busy to try and chase it up.
  • Isn't this bug linked to the one I had submitted to support?:
    feezing on PAN (quick gesture, also in Model space)
    Switching the user pref 'PanBuffer' as advised seems (at first tests ...) improving the thing
    HTH
    PYD
  • Scratch what I said before; it has only happened in model space as far as i know.
