Poly line Fill Gone
I use polylines onmy drawing.  Normally the interior fill is the same color as the outline.  On one drawing the interio is transparent.
Is there a setting to correct this?
  • Set FILLMODE to ON and do a REGEN.
  • FILLMODE was already on but I turned it off and on again and did a regen but they where still not filled.
    I ended up copying everything in the drawing to a new drawing and the fill came back.
    Thanks.
  • Your problem can also be caused by an accidental 3D-view. If the Z-axix of the polyline and the view direction are not parallel, the polyline is shown without fill.
  • I think it was the rotation problem.  Not sure how it got rotated but going to View, Plan View, UCS and hitting enter fixed it.
    Thanks.
