line
When I try to draw a line, with esnap mode on, I see a circle and a line near the cursor?What is that, what is the usage?
The symbols that appear next to the cursor indicate the running object snaps that are active. A circle and a line indicate multiple running object snaps are active simultaneously. In case only one snap is active, the symbol indicates which snap is selected.Regards,Louis
thank you for the info. is there a way to turn off these circle and the line when entity snap is still active?
