isometric detail
Greetings,
Sometimes I should combine two types of details in the same view or plan, for example. to have a top view of a house with is water pipe net and and isometric view with the high of the stuffs (shower, faucets, etc)
if I want to have normal top view plan of a house and an isometric view of the same house, in Autocad I use the isometric views and I chose the respective view and after I copy all and in Edit menu I use paste special and I click in bitmap or metafile, and I paste... in this moment I have a kind of image, after I cut this image and I use again special paste and click on Autocad entity and paste it, the result and isometric drawing exported from the isometric view.
I have been trying to do the same in bricscad but I could not do it. Exist other way to do this?
thanks
J.M.
I think two viewports in a paperspace layout can do such job. Each viewport can have its own orientation and display settings.
