I need help from developers / programming LISP people / Visual LISP / objectARX
New program exist in internet:
Subject                                                 EXTREM MathematicalLISP,Generator LISP,Convertor C to LISP, Convertor lisp to C,C++,
                                                              build profesional LISP, objectARX with visual LISP function!, Build Big lisp program, Build BIG LISP program
Name program : TopoVlexC.exe
MyMessage : I search people developer ObjectARX.. for build library-driver in BrisCAD...or LISP program for colaboration via internet
                        For build big lisp program in BrisCAD .........
Convert more easly lisp to C because already  in C++ all lisp program)
This program is only a test version.You can write mathematical equations directly in LISP, !!!!!!!!!!!!!!!
as such m, the following (real-equations)
y2=r2-v2*tan(r2,"r")/w2*(x2*x2/2-(5+3*u2+10*t2-4*t2*t2-9*s2)*power(x2,4)/24+(61+90*u2+298*t2+45*u2*u2-252*s2-3*t2*t2)*power(x2,6)/720),
z2=h2+(x2-(1+2*u2+t2)*power(x2,3)/6+(5-2*t2+28*u2-3*t2*t2+8*s2+24*u2*u2)*power(x2,5)/120)/cos(r2),
r2=q2+sin(q3)*(3*n2/2-27*power(n2,3)/32)+sin(q4)*(21*n2*n2/16-55*power(n2,4)/32)+sin(q6)*151*power(n2,3)/96+sin(q8)*1097*power(n2,4)/512,
s2=d2*d2/(1-d2*d2),
r2=s2*cos(r2)*cos(r2),
u2=tan(r2,"r")*tan(r2,"r"),
When link your program , result on disk file LISP program with extensnion file name .lsp
Downloading test version from (limited at library = 200ko size on disk)
Avi file2 =  http://www.megaupload.com/?d=TCI5TP82                   + test version1
 Unzip files, view all movies, path new drive L: C:\...,
Avi file3 =  http://www.megaupload.com/?d=CTZSOYYF                   + test version2
LISP can generate fractals?             http://www.megaupload.com/?d=4VHTCH9N
Avi file4 =  http://www.megaupload.com/?d=CTZSOYYF
Avi file5 =  http://www.megaupload.com/?d=5V58YKP3 (list all function, only movies)
Avi file6 =  http://www.megaupload.com/?d=BT0CQ8YW                       Increment numeric value of text object
Main program is not open - source, but libraries are open - source with
1. downloading zip file from adress http://www.fileshare.ro/5288855552 in disk c:\TEST
2. unzip file to C:\TEST
3. Preview file avi : pp_asdk_jeanfrancois.avi
4. Preview avi file : "C:\TEST\FREE\make drive L3.avi"
5. make drive L: with patch_vdm.exe
L: == C:\TEST\FREE
or loading program vlx : pp_asdk_jeanfrancois.vlx and enter command Q2 [ enter]
6. run batch file L:\BTLS\_runfree_ls2.bat
Os Requirements: WindowsXP+....
7.explorer L:\0User
8.notepad L:\0User\ pp_asdk_jeanfrancois.lsp
9.Sorry for bugs is only version 1.0
Alles gutes..
Convert math+C equations to lisp , and build your library lisp. NEW UPDATED!!!!!
Convert smallC# to lisp., cpp2lsp, convert c+ to lsp
Features (free register version):
a) Function convert TEXT file into string lisp or include one text file into string lisp
( e.g. create RTF file )
b) Include DCL file into lisp, you don't need search DCL on disk
c)Convert LISP one block (progn..) TO C script
d) Build big LISP program more easy. Size fo VLx file =200..300ko..
e)38 procedure for customize you wish dialog boxes:
f) Adding function lisp to library..........
g) Convert mathematical equations in lisp codes...
h)Include MNU (menu files ) for AutoCAD in yours LISP programs, activate and enabled.
i)Convert math equations to lisp, or C++ to autolisp, cpp2lsp, ctolsp,c2lsp
------------------------------DEMOS 4-----------------------------------------------------------
  • Can you build BIG LISP program in classic mode  in Visual LISP (autolisp) or complex program ?
    I can build big  program lisp  with powerfull language C+ , very powerfull lagunage C+..
    I dcn't think you can build one complex program in Visual LISP as ...              downloading...          http://www.megaupload.com/?d=714HTBYL
  • The download link is for: pp_topoglistPENTIUM3.vlx but Bricscad cannot load vlx-files.
