BricsCad in Ubuntu 10.04 / Trying to Open DXF File BricsCad Close
When you try to open a DXF by Double Click the Bricscad suddenly open and after close, the file was designed with QCAD
but if you first Open the BricsCad, after FILE / OPEN, there is no problem it read the File.
