ver 27 break command
Anyone notice that when breaking a line a lag in accepting point definitions? Case in point:2 lines intersect. I wish to break one of them into 2 entities at the intersecion point of the existing lines. Intersection Snap is set on, I preselect the line, invoke BREAK command then click at intersection and quickly click same point again. Intellicad (ver 27) doesn't get second point. If I hesitate a second or two and then click same point it works fine. Didn't notice this behavior in previous versions.Comments?
  • I have noticed sporadic quirks with the "intersection" snap. With the break command and with the measure command for obtaining the length of a line. Sometimes it works very well. Other times it seems to be overwhelmed by the number of possible entities available rather than focusing on a single intersection.
