v 2.2.0027 problems
I'm having several problems with 2.2.0027. Has anyone else seen these?1. Solid hatch will not print (though it shows in Print Preview).2. Undo does not always go in reverse sequence.3. Several problems with text- a. when Zooming text does not always Zoom proportionally with the rest of the drawing. b. text does not insert at the crosshairs, but rather inserts at some distance far from the crosshairs. c. when Inserting drawings as blocks the text breaks away from the drawing with different text going in different directions.
  • Regarding post 1 solid hatches prints on some printers when it shows in preview.My HP laserjet takes it bu not my Canon BJ.
