Previus selection
In version 10.2.9 in Spanish P command is used for the previus selection, however in version 2.10.1912 and later used PRE. I prefer to use the P command, is it possible to configure it?
  • In version 10.2.9 in Spanish P command is used for the previus selection, however in version 10.2.12 and later used PRE. I prefer to use the P command, is it possible to configure it?
    Thanks
    Thanks
  • Not using Spanish version, but you can try to change Command Aliases in your default.pgp file:
    P,              *PRE
  • Thanks but it does not work.  PRE is in _SELECT command and i can't  configure in my default.pgp
  • Oh, you are about 'previous' option for selection?
    Must work _p
