vba can't set the arrowheadtype
Dear Sir :
  I NEED A HELP !!
WHEN I RUN THE VBA FOR BRICSYS CAD , I WANT TO CHANGE THE ARROWHEAD1TYPE & ARROWHEAD1TYPE  LIKE :
returnObj.Arrowhead1Type = acArrowDefault     ( THE ARROWHEADTYPE CAN'T CHANGE TO DEFAULT)
BUT
returnObj.Arrowhead1Type = acArrowDotSmall   CAN CHANGE TO SMALL-DOT
I TRY THE SAME VBA PROGRAM ON AUTOCAD , AUTOCAD CAN CHANGE THE ARROWHEADTYPE TO DEFAULT
THANKS
  • DIR SIR :
    MY VBA CODE :
    Public Sub MOD_ARROW1()
        Dim returnObj As AcadObject
        Dim basePnt As Variant
        On Error Resume Next
        ThisDrawing.UTILITY.GetEntity returnObj, basePnt, "SELECT DIM :"
            If Err <> 0 Then
                    Err.Clear
                Exit Sub
            Else
                returnObj.Arrowhead2Type = acArrowDotSmall
                returnObj.DimensionLineExtend = 0
                returnObj.Update
            End If
    End Sub
    THANKS
