Maximize view port
A feature in autocad that I love and use often is the "Maximize View Port" button.  When working in a locked view port I can hit this button and enter model space through the view port.  Does bricscad have anything like this or any add on's have this feature?
  • If you double click inside a locked viewport then you can edit model space elements.  Then to get back to paperspace just click on the toggle on the statusbar (bottom right of screen).  Admittedly the only model space elements you can edit are those that were visible through the viewport; but I imagine if there is something you thought about editing while  in paperspace then this is probably the case.
