An error occurred while rendering entity 119: Out of memory
Hello,
i am trying to print a clipped raster with added layers and a template.
In the preview the correct image is displayed, but when i print the following error occurs
The image prints but without the raster and without some of the template.
If i delete the raster then everything else prints fine, so it must be an issue with the raster.
However if i just print the raster, with nothing added to it then this works. Although it does seem to take alot out of my computer!
Any ideas would be great.
THanks
Hello,
i have solved the problem by converting the raster from 24-bit to 8-bit. Works fine now.
Regards
