Bricscad won't run
I installed BricscadClassic-V10.4.9-1-en_US.deb package into my Ubuntu installation and Bricscad works fine. After a while not using it I found it won't start up anymore.
I tried reinstalling the software without luck. The error I get on my terminal window is:
$ ./bricscad.sh
bricscad: /home/build/dev/ddcad.autobuild/ddcad/src/utils/ut_print_data.cpp:632: void ut::PrintData::readFromRegistry(ut::Registry&, const OdString&): Assertion `!printerName.iCompare(strValue)' failed.
Cancelado
I'm using Ubuntu 10.04 with this uname -a:
Linux clemare-laptop 2.6.32-23-generic #37-Ubuntu SMP Fri Jun 11 07:54:58 UTC 2010 i686 GNU/Linux
Thanks.
I get the same error.
I'm using Ubuntu 10.04 64bits
same bug with me (on ubuntu 10.04 64 bits)
Try to remove ~/.bricscad folder. If the problem persists, also remove ~/.bricsys and ~/Bricsys directories. After that you will have like a newly installed Bricscad (Linux).
strangely, it works again launching with gksudo
luis miguel pinto gonçalves
It works because the application is launched as root, thus it uses the configuration directories from /root not from /home/your_other_username
and what's the way to solve the problem? I have already erase Bricscad directory and reinstall with the same bug.
Well. remove the ~/.bricscad works fine. I don't know why I don't think in that... it's obvious.
Thanks for the tip!
clemare
works fine now. thanks
