URGENT - 10.4.16-1 doesn't start
I just downloaded and installed BC 10.4.16-1.
When I want to start the program a message pops up stating that : "MiniDumpWriteDump" wasn't found
in "dbghelp.dll". That's all, now what ?
I hesitate to uninstall BC as I would probably loose all my settings.
But if I had to uninstall it, can I install an older version (10.4.10-1 is still around) ?
  • FYI: If you uninstall 10.4.16, you can install any older BC version.
    Concerning the problem you experience:
    in 10.4.16 we added the possibility to write miniDump crash log files. The fact this is causing additional trouble is the opposite of what we had in mind. We will post an update in the coming hours and temporarily disable this feature till we have found out and fixed what causes this behavior.
    We apologize for the trouble.
  • I'll wait for the update then. Thanks for the effort Hans.
  • Just a note to let you know V10.4.17 is available for download.
  • All is well now Hans. Thanks again.
