batch plot - not using plot styles
i need help while batch plotting. i did everything what is said in the video http://www.bricsys.com/common/movie.jsp?id=11
it works fine BESIDES that he is not using my plot styles. even though the PEN STYLE TABLE is there when i open it on the Bricscad Batch Plot Utility.
what do I have to do?
  • It seems you have hit upon a bug in the -PLOT command (BatchPlotTool uses this command).
    If I PRINT using monochrome.ctb the result is in black and white.
    If I use the -PLOT command (Detailed plot configuration: Yes) and specify monochrome.ctb the result is in colour (BC 10.4.17).
    Please file a support request!
