slow in running a text script? three times slower than autocad
if you run a script file, bricscad is 3 times slower than autocad 2006. Why is that?
Is there any way you can suppress the demonstration of the code being run so that the machine doesnt spend time typing in the commands?
  • turning off the cmdecho might help a little but still autocad 2010 on windows was 10 times faster than bricsys on linux
    PASTE CODE HERE
