bamboo fun tablet
Hello,
I work with V10 and would to work with a tablet, i've got a bamboo fun tablet to test if i like to work with a tablet.
I can draw with it, but can not assign the buttons or pan with it...
if I type tablet , i get an error : Required file WinTab32.DLL not found,
I work with windows 7 - 64bit....
Any one knwo the answer ?
thx
I had an Intuous which I think works a little differently - you assigned button strokes and pointing area using the Intuous software.
It also had touch strips for scrolling and/or assigning commands to. Commands or functions which meant something to Bcad would work in Bcad, also true for button reassignments.
I believe Bcad's Tablet command is to assign a tablet menu and pointing area. Seems to me there will be a confusion with pointing area being set by 2 different programs, but I stopped using tablet menus a long long time ago so I didn't use Tablet command.
Looks like the Bamboo works more like a touch pad (?). If you can work out what Bcad understands by a certain action of the tablet, or reassign the tablet function to be what Bcad expects, you might get it to do what you want. There are a few Bcad settings which might lend it better to preferred mouse functions, such as Mbuttonpan, but generally I find it best to look to the pointing device to make mouse customisations.
I gradually screwed my tablet area to about 30mm wide (years before the Wacom) - boy was I fast, but that was where my arm pain began and now it's trackballs exclusively for me.
Steven
I think the 'WinTab32.DLL not found' indicates the driver software for the tablet is not installed properly. Can you check that?
Just visit this site...
http://www.fix-all-dll-errors.com/wintab32.dll/
this will help in case of missing or downloading dll's .
helped in my problem.
